Date/Time: Wed, 12 Feb 2025 13:21:21 +0000
Two instances of same chart during replay
View Count: 535
[2020-10-30 18:01:12]
User290496 - Posts: 62
I cannot find any information on this:
Is it possible to have two copies of the same chart playing during replay SIM trading?
I would like to have one zoomed out to see the whole day, with my markings and lines appearing on it, and have one more zoomed in where I trade off of.
Cheers
[2020-10-30 18:25:52]
John - SC Support - Posts: 37891
Yes, you can do this. Just select one of the appropriate options from the Replay Control Panel to replay both charts. Refer to the information here:
https://www.sierrachart.com/index.php?page=doc/ReplayChart.html#ChartsToReplay
[2020-10-30 21:41:32]
Hi John,
I am aware of being able to duplicate the chart and have replay going on both synced, however- I cannot figure out how to get drawings on one to automatically show up on the other as I am doing them.
For example, I have one chart zoomed out so I can see a full day.
Another chart zoomed into the area I am currently trading. If I place a line on one chart, I would like it to show on the other chart as well.
All this while trading in replay SIM mode.
Is this doable?
[2020-10-30 21:48:44]
Refer to the following setting:
Chart Settings: Copy Chart Drawings from Chart #'s (Chart >> Chart Settings >> Chart Drawings menu)
[2020-10-30 23:03:44]
That's the one!
Thank you very much!
Cheers
