Date/Time: Wed, 12 Feb 2025 13:23:26 +0000
TPO Chart issue
View Count: 530
[2020-10-30 13:54:09] |
User894550 - Posts: 20 |
I have an issue with my TPO Chart. The TPO's do not show properly, it is out of whack, this has happened to me before and I do not understand what could be the issue with my chart. please advise me on how to resolve this issue. Please find attached a screenshot of my TPO Chart. Looking forward to hearing from you. Regards, http://www.sierrachart.com/image.php?Image=1604065983736.png |
[2020-10-30 16:40:09] |
John - SC Support - Posts: 37891 |
Attach a Chartbook with that chart in it to this thread following these instructions: Support Board Posting Information: Providing Chartbook with Only a Single Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-10-30 19:23:00] |
Change this TPO Profile Chart study Input to 20: Time Price Opportunity (TPO) Profile Charts: Letter/Block Price Increment in Ticks See if that resolves the problem. Once it does, then you can then adjust it to a smaller value. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-10-30 20:08:42] |
In the TPO Profile Chart study, which value do you want me to change to 20 ?
[2020-10-30 23:52:06] |
