Date/Time: Mon, 13 Jan 2025 21:31:21 +0000
[User Discussion] - Extend Bar Value Until Future Intersection Help
View Count: 1834
[2020-10-30 13:25:33] |
User158665 - Posts: 44 |
I am trying to extend POC in a weekly and daily chart chart but using Volume by price makes the chart too slow and difficult to use. When I try to use Volume Point of Control for Bars + Extend bar Value until Future Intersection, the extended price for POC does not stop when intersected. How Can I do that? |
Attachment Deleted. Bar Value until Future Intersection.png / V - Attached On 2020-10-30 13:24:33 UTC - Size: 54.86 KB - 427 views Bar Value until Future Intersection 2.png / V - Attached On 2020-10-30 13:24:38 UTC - Size: 77.43 KB - 381 views |
[2020-10-30 13:58:48] |
Ackin - Posts: 1865 |
Hi, I can see from the name of the study (zyp) in the header in the chart that you are registered in our forum. Give me an hour and I will give an update for the study from the default Sierrachart list improved by what you need ... |
[2020-11-04 23:36:04] |
Why when I try to use "Extend bar Value until Future Intersection" + "Any POC study" the extended line goes beyond the intersected bar?
2191 Future Intersection.png / V - Attached On 2020-11-04 23:35:09 UTC - Size: 129.64 KB - 410 views 2191 Future Intersection 2.png / V - Attached On 2020-11-04 23:35:25 UTC - Size: 77.14 KB - 398 views |
[2021-10-10 13:42:40] |
User583603 - Posts: 2 |
Is it possible to display the "average price for bar" or "VPOC for bars" only in inside bars. I tried both Studies, but i can not choose a special type of bar AND i want a line until the next inside bar is built. Thanks, erwin http://www.sierrachart.com/image.php?Image=1633873330895.png |
[2021-10-10 15:19:46] |
John - SC Support - Posts: 37181 |
With regards to Post #4, this is not supported within Sierra Chart. You could do what you want by building a custom study and then updating the extension lines when a new inside bar is detected. Refer to the following for the information on custom studies: Advanced Custom Study Interface and Language (ACSIL): Introduction For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-10-10 16:41:14] |
Okay. thank you
