Date/Time: Wed, 12 Feb 2025 13:00:20 +0000
Dom graph on chart - send to back
View Count: 568
[2020-10-30 12:49:47] |
User255336 - Posts: 28 |
Is there any way to send the DOM graph that's overlaid on the chart to the back? I have a study that plots prices to the right hand side of the chart, but the DOM graph is covering up the numbers, making it difficult to read. My custom study is ordered all the way to the top in the study settings. See attached file for reference. As always, I appreciate your time. |
Private File |
[2020-10-31 00:21:45] |
No but you can change the Subgraph Value Label alignment to be like this : http://www.sierrachart.com/image.php?Image=1604103626579.png And then you can create space on the right side of the chart between the DOM graph and the last bar: Working With Charts: Right Side Fill Space Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-10-31 00:22:21
