Date/Time: Wed, 12 Feb 2025 13:05:21 +0000
orders
View Count: 510
[2020-10-30 12:15:07] |
Alezar - Posts: 1 |
i had a stop order to open last night. It opened but the target and stop did not work costing me more points than i had risked and the target profit actually hit.
[2020-10-31 02:02:08] |
This is because you are using CQG and there are not server side bracket orders supported with that service. Have your broker change you to the Sierra Chart Order Routing Service which supports server-side bracket orders: Sierra Chart / Trading Technologies Futures Order Routing Service To get started with this, complete this form: https://www.sierrachart.com/UserControlPanel.php?page=SCOrderRoutingServiceTradingAccountAssignmentRequestForm Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-10-31 02:03:03
