Date/Time: Mon, 24 Feb 2025 22:29:58 +0000
TPO standard Profile + TPO letter in own column: Side change
View Count: 1538
[2020-10-30 08:53:17]
User210127 - Posts: 23
First of all, thank you very much for implementing this feature, this is great and was much needed so than you for the great work.
Question: The letter/block in own column is displayed on the left, and on the right the actual TPO profile is shown. Great. Is there a way to change this so we have the TPO profile on the left and the actual each letter/block in its own column to the right of the TPO profile?
Thank you again.
[2020-10-31 01:44:32]
We will have to add an option for this.
[2020-10-31 11:30:31]
That would be fantastic, thank you very much.
[2020-11-02 20:33:05]
User120942 - Posts: 74
@Sierra Chart Engineering
Just wanted to +1 in support of the request from User210127. I'm not sure what happened from version 2182 to version 2191 regarding the sequence of the TPO profile and split profile but I recall that in version 2182 the TPO Profile was displayed to the left of the Split Profile (see the attachment from Ticino Trader's twitter feed when the update was first announced).
I know everyone has different preferences so having a setting to choose the sequence is a good suggestion.
The recent updates of the TPO study are much appreciated.
Thank You
imageTPO Split Profile from Ticino Trader's twitter feed.jpg / V - Attached On 2020-11-02 20:30:25 UTC - Size: 250.23 KB - 507 views
[2020-11-09 15:20:38]
User968625 - Posts: 260
Hello, any update on this, can we have the "in its own cloumn" on the right of the stndard profile. or maybe an option to chose if others have asked for it to be on the left. (Jim Dalton uses it on the right and this is where most followers use it)
Date Time Of Last Edit: 2020-11-09 15:21:55
[2021-03-26 10:24:11]
adam84 - Posts: 2
Hi, I was wondering if an option to switch the sides of split/compressed profiles has been added? Many thanks
[2021-03-26 11:22:52]
+1, Jim Dalton is where most of TPO followers learn from an he uses it on right, would be great to really add this option. I know you are busy but I hope it is an easy one
[2021-03-26 14:37:05]
John - SC Support - Posts: 38148
Refer to this Input:
Time Price Opportunity (TPO) Profile Charts: For Profile in Own Column and Standard Profile, Standard Profile on Left
