Date/Time: Wed, 12 Feb 2025 12:47:31 +0000
Prices incorrect for Open, High, Low Close
View Count: 1029
[2020-10-30 03:59:59]
like2trade - Posts: 117
I displayed the following prices for Silver futures SIZ20 in the message log. I am using these numbers in ACSIL logic and it is not working because the Silver prices should be up to only 3 digits after the decimal point. The following numbers contain a 1 and 2 as the last digits which is not supposed to happen. Do you know what the problem is?
O: 23.370001, H: 23.370001, L: 23.365002, C: 23.370001
This is the code that produced this in the message log.
MessageText.Format("O: %f, H: %f, L: %f, C: %f", sc.Open[sc.Index - 1], sc.High[sc.Index - 1], sc.Low[sc.Index - 1], sc.Close[sc.Index - 1]);
sc.AddMessageToLog(MessageText, 0);
Thank you.
[2020-10-30 08:40:19]
Ackin - Posts: 1865
Try in your code change
%f
to
%.3f
Date Time Of Last Edit: 2020-10-30 08:42:50
[2020-10-30 08:57:37]
Hi Ackin,
I tried your recommendation and now the output is:
O: 23.3700008392, H: 23.3800010681, L: 23.3700008392, C: 23.3800010681
The problem for me is not really the output, but the fact that there is non zero digits after the 3rd decimal place. I am comparing sc.Low[sc.Index] and sc.ChartTradingOrderPrice and it is not giving me the expected result. I am having to truncate sc.Low[sc.Index] to 3 decimal places in order for my logic to work. For example sc.ChartTradingOrderPrice = 23.365000 but sc.Low[sc.Index] = 23.365001. This should not be happening.
Thank you.
[2020-10-30 09:06:19]
Ackin - Posts: 1865
I don't know, it occurs to me that this is not important if the main values are accurate. Try using the function to round to the nearest tick (round to tick) and then check the main swings, for example with another platform or online chart data. I think it will be the same as what you see after rounding here.
[2020-10-30 09:14:59]
Of course I could program a work around, but the point is that this should not be happening. I am hoping that Sierra Engineering can shed some light on this.
Thanks.
[2020-10-30 10:22:59]
This information is written in relation to Spreadsheets but also applies here as well:
Using the Spreadsheet Study: Imprecision of Floating-Point Numbers and Comparisons
[2020-10-30 15:55:42]
Thank you for the link Sierra Engineering. What is the best way to handle this in ACSIL? Can you please provide an ACSIL example.
Thank you very much.
[2020-10-30 16:19:06]
FYI, I will be using the same study on instruments that have 2, 3, 4, and 5 decimal places. So the solution would have to be generic.
Thanks.
Date Time Of Last Edit: 2020-10-30 16:22:25
[2020-10-30 22:27:57]
User907968 - Posts: 826
sc.FormattedEvaluate()
[2020-10-31 02:01:34]
This worked perfectly. Thank you very much.
