Date/Time: Wed, 12 Feb 2025 13:49:39 +0000
Cannot delete old chartbooks, though your instructions have been followed to the letter...
View Count: 625
[2020-10-29 20:45:54] |
User176700 - Posts: 2 |
I moved to Infinity Futures from AMP and when I made the charting service choice at TransAct Futures, a bunch of old chartbooks loaded. I have followed your instructions for Deleting a Chartbook, but that does not delete them. I have gone to the Sierra Charts Data Folder and tried to delete them from there. No change. I have gone to the "Which charts to load on startup and deleted them from there. Same result. They remain. How can I get rid of these chartbooks? Thank you.
[2020-10-30 00:28:10] |
You need to disable file downloads here for your account: https://www.sierrachart.com/UserControlPanel.php?page=EnabledCustomStudies#FileDownload Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-10-30 00:28:20
