Date/Time: Wed, 12 Feb 2025 13:28:01 +0000
Unique Formula Source Sheet
View Count: 589
[2020-10-29 20:30:24] |
User606491 - Posts: 164 |
For the Spreadsheet System for Trading study: Is there a way to change the settings so that each sheet is automatically considered its own formula source sheet? Use case: A spreadsheet study is part of a larger study set composite. When I copy that composite study set onto a new chart, I have to manually change the Formula Source Sheet Number. This is fine when adding 1 or 2 new charts, but becomes cumbersome and error-prone when adding several new charts. Alternative solutions are welcome. |
[2020-10-31 02:00:25] |
Have a look at this Spreadsheet Study Input: Spreadsheet Study Inputs: Always Set Formula Source Sheet to Chart Data Output Sheet Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-10-31 02:00:43
