Date/Time: Wed, 12 Feb 2025 13:36:58 +0000
[Programming Help] - Additional Control in Chart Settings
View Count: 462
[2020-10-29 19:39:13]
User92573 - Posts: 544
Dear Support
I have checked on Support Board and John (SC) has also confirmed the functionality required is currently not available. I would be happy to contribute towards the programming of this if it can be factored in to your current programming work load. I certainly think it would be greatly received by many Sierra Chart users if not at cost to the platforms speed.
Currently you can use the Global Settings - Graphics Settings Global - to define and load alternative graphics settings however this is not available at chart-level.
Is the any way that the drop-down control can be included in chart setting that would allow numerous configurations? The questions would be as follows:
1) Is this possible and if so what would be required cost-wise for it to be programmed?
2) Would this additional flexibility if provided have an impact on the speed of SC or the hardware? i.e. would it create any additional workload?
Lastly, is it currently possible to run a second instance of Sierra and apply a different Global Graphic Setting from the initial instance?
PS Many thanks for the increasing the number of Custom Text Drawing in the Toolbar to 200.
Thank you.
imageSC - Graphics Settings - Global.png / V - Attached On 2020-10-29 19:38:25 UTC - Size: 162.65 KB - 196 views
