Date/Time: Wed, 12 Feb 2025 14:14:47 +0000
Intraday chart not updated when Date Range is used
View Count: 551
[2020-10-29 16:39:04] |
User235957 - Posts: 2 |
After one of the recent updates some of my intraday charts that use Date Range stopped being updated. I can see the current price moving on the vertical axis and on the top of the chart but the chart itself doesn't change. The chart uses Date Range, if I switch to Number of days it starts working. I can manually reload and recalculate the chart and it updates to the current time but doesn't update going forward. I attached a sample chartbook to illustrate the problem. Also attached an image, as you can see the current time is 13:13:49 but the chart hasn't updated since 12:10 or so. http://www.sierrachart.com/image.php?Image=1603991630425.png Date Time Of Last Edit: 2020-10-29 17:16:10
[2020-10-29 17:31:44] |
John - SC Support - Posts: 37891 |
Are you only having this problem in a Sub-Instance?
[2020-10-29 17:33:44] |
No, it's in both - main and sub-instance.
[2020-10-29 19:12:37] |
We are resolving this now. We will have a new revision out in a few minutes. At that time update: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
