Date/Time: Wed, 12 Feb 2025 13:56:38 +0000
Possible to download OHLC in txt file from a continous contract?
View Count: 546
[2020-10-29 16:19:06]
User339484 - Posts: 71
When I do edit data historical chart, it only pulls up the last contract and not continuous as on the chart.
If I switch it to intraday data and use 1 day candles it doesn't use adjusted close and some earlier data is missing.
[2020-10-29 17:02:28]
John - SC Support - Posts: 37891
You would need to setup the chart as you want it then use the Edit >> Export Bar Data to Text File. Refer to the information here:
Edit Menu: Edit >> Export Bar Data to Text File
[2020-10-29 21:09:48]
Refer to:
Also refer to the post above.
Date Time Of Last Edit: 2020-10-29 21:09:56
