Date/Time: Wed, 12 Feb 2025 13:48:15 +0000
Value Format inconsistent for Number Bars Calculated Values.
View Count: 484
[2020-10-29 15:28:18]
User978405 - Posts: 6
Ever since the recent Sierra update, the Number Bars Calculated Values shows large integer with suffix only for the top most row. And changes to the same setting only changes it for the top most row, the others are unaffected and show the full numbers.
Kindly help me with this.
Thank you.
imageSierra.png / V - Attached On 2020-10-29 15:27:34 UTC - Size: 122.35 KB - 185 views
[2020-10-29 20:56:06]
This is now resolved. Update to version 2189:
[2020-10-29 23:41:04]
Thanks. It's fixed.
Cheers!
