Date/Time: Sat, 04 Jul 2026 04:55:14 +0000
How too get the difference of the YM
View Count: 887
[2020-10-29 15:17:57]
Tonkadad - Posts: 235
How can I get the actual difference between yesterdays close of the YM relative to real time. In other words I have a
text box showing the real time price of the YM but what I want is the actual difference from yesterday and current price.
It would be a positive or negative number.
If there was a way to color the background of textbox to correspond with +/- that would be nice.
[2020-10-29 16:35:09]
John - SC Support - Posts: 47017
You can get the difference as a Percentage using this study:
Percent Change Since Previous Close
Depending on what you use to display the data, you could use the Color Bar Based on Alert Condition to change the color based on +/-. For instance, you cannot do this with the Text Display for Study, but you could with Study Subgraph Above/Below Bar as Text study. Refer to the information here:
[2020-10-29 16:38:16]
Ackin - Posts: 1865
or another solution to do:
Study Daily OHLC + Arihtmetic studies + Text Display For Study
Daily OHLC (try parameter "Reference Days Back:")
Daily OHLC
Using the Basic Arithmetic Studies (for you: Study Subgraphs Subtract/Difference)
Text Display For Study | Text Display For Study from Chart
btw "If there was a way to color the background of textbox to correspond with +/- that would be nice."
I have custom study for that:
10) Text Display from Study - Background based on positive/negative
Ackin's indicators (SCH users requests for studies) - Update list | Post: 170827
[2020-10-29 17:02:23]
Thank you so much for your time and input, Ackin!
As always SC, you guys are the best.
