Date/Time: Thu, 17 Sep 2026 02:51:32 +0000
2 systems 1 datafeed
View Count: 820
| [2020-10-29 15:13:03] |
| Timo Costa - Posts: 28 |
Hallo. Ich möchte auf einem anderen PC mein zweites system aktivieren. Kann ich meinen aktuellen datenfeed dort auch mitnutzen oder muss ich ein neuen kaufen? Vielen Dank
| [2020-10-29 16:01:34] |
| John - SC Support - Posts: 47917 |
From Google Translate: Hello. I would like to activate my second system on another PC. Can I also use my current data feed there or do I have to buy a new one? Many thanks
You would need to ask your data provider that question. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2020-10-29 21:05:30] |
If you use the Denali Exchange Data Feed you can use it on two separate systems at the same time if you pay the exchange fees twice: Denali Exchange Data Feed Also refer to: Sierra Chart Purchase and License Information: Licensing / Number of Systems Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2020-11-02 11:55:53] |
OKay vielen dank . Wenn CME & EUREX gebucht werden besteht eine Rabatt Möglichkeit? |
| [2020-11-02 14:51:30] |
From Google Translate: Okay thank you very much.
If CME & EUREX are booked, is there a discount option? Yes, if you want both the CME Group and EUREX, then you would need to have both the Denali Exchange Data Feed (for the CME Group) and the Sierra Chart Exchange Data Feed (for the EUREX). When you are paying for both of these data feeds in the same month you will receive a $10.00 USD credit to your account that month. Refer to the information here: https://www.sierrachart.com/index.php?page=doc/RealTimeDataFeedsAvailableFromSierraChart.php#UsingBothDenaliExchangeDataFeedAndSierraChartExchangeDataFeed For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
