Date/Time: Wed, 12 Feb 2025 13:54:18 +0000
Real-time data
View Count: 460
[2020-10-29 15:12:35] |
Declan Hewitt - Posts: 1 |
Hi, I am currently on the delayed data feed service, and I wanted to upgrade to the live data feed service without linking a trading account to it but I am not sure what is the correct service for this. Can you tell me which specific service I would need in order to do this? Thanks, Declan |
[2020-10-29 15:44:32] |
John - SC Support - Posts: 37891 |
First, you need to be aware of the requirement of the CME Group that you have a funded trading account in order to qualify for the non-professional exchange fees. Refer to the information here: Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges If you do not have a trading account that you can connect to, then we recommend the service outlined in the following link: Easy Solution to CME Funded Trading Account Requirement The answer to your specific question is that you would use the Denali Exchange Data Feed for the CME Group data. Refer to the information here: Denali Exchange Data Feed For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
