Date/Time: Mon, 05 Oct 2026 10:51:38 +0000
Numbers Bars Diagonal Imbalance Settings
View Count: 3048
[2020-10-29 13:14:31]
DancyAnd - Posts: 7
I cannot get my Diagonal Dominant Ask Bid Imbalance setting for Column 1 Text to work correctly with the Background setting for my chart.
Column 1 Background - Based on AskVol/BidVol percentage
Column 1 Text Coloring - Based on Diagonal Dominant Side AskVol BidVol Percentage
Column 1 Percent Compare Threshholds - 0.25,0.5,0.75 (For the Background Coloring)
Use Separate Colors for Text Coloring - Yes
Range 3 Up Color for Text- Set to Teal
Range 3 Down for Text - Set to Magenta
Column 1 Actual Volume Compare Thresholds - 0,0,3 - for a 300% imbalance.
The attachment shows that the Background Coloring is working fine but the Imbalances are wrong.
imageNumbers Bar Example.PNG / V - Attached On 2020-10-29 13:12:30 UTC - Size: 42.18 KB - 608 views
[2020-10-29 13:43:48]
John - SC Support - Posts: 48095
Even though you can use separate colors for the text, there is still only one Percent Compare Thresholds input. Therefore, you are still using thresholds of .25, .5, and .75 for the text.
The best option is to use a second column for the text coloring.
Also, be sure you set the Range 0 to Range 2 colors for Text Coloring to be a color that you can ignore (white or black, or the same as background to not see them at all).
