Date/Time: Wed, 12 Feb 2025 14:19:17 +0000
File compression error
View Count: 1028
[2020-10-29 11:03:49] |
ertrader - Posts: 681 |
Hi Support, for SC 2189 on Linux/Wine, I am seeing the error below. Should I just disable compression? File compression not supported on file system. C:\files\Sierra_Data\MESZ20.dly. Windows error code 50: Request not supported. | 2020-10-29 06:54:04.474 File compression not supported on file system. C:\files\Sierra_Data\MESZ20.scid. Windows error code 50: Request not supported. | 2020-10-29 06:54:08.938 Date Time Of Last Edit: 2020-10-29 11:12:47
[2020-10-29 20:46:42] |
There is no way to disable file compression. Not sure why there was an attempt to compress a daily data file: C:\files\Sierra_Data\MESZ20.dly. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-10-29 20:49:19
[2020-10-29 21:54:53] |
So ignore the error and everything is OK?
[2020-10-29 23:16:15] |
Yes you can safely ignore it and we will think about not showing it.
