Date/Time: Wed, 29 Jul 2026 04:54:47 +0000
DRAWSTYLE_TRANSPARENT_CIRCLE_VARIABLE_SIZE_WITH_BORDER border color?
View Count: 781
[2020-10-29 10:25:26]
User311344 - Posts: 142
Hey,
How can I set unique border color for each element of a sc.Subgraph[].Data[] array when using DRAWSTYLE_TRANSPARENT_CIRCLE_VARIABLE_SIZE_WITH_BORDER draw style?
I set the circle color with:
sc.Subgraph[i].DataColor[sc.Index] = RGB(0,0,0);
but how can I set the border color itself to make it match the circle color? Thanks
PS: Should I use sc.CombinedForegroundBackgroundColorRef() maybe to combine both colors? If not could you do that so it works like that? Thanks! (EDIT: I just checked, it doesnt work like that).
Date Time Of Last Edit: 2020-10-29 10:37:55
[2020-11-04 18:22:32]
Any info on that? Thanks
[2020-11-05 14:52:00]
John - SC Support - Posts: 47375
You cannot set a unique border color for each element, like you can for the Primary Color. But you can control the overall color of the border using the SecondaryColor member of sc.Subgraph. Refer to the information here:
ACSIL Interface Members - sc.Subgraph Array: sc.Subgraph[].SecondaryColor
