Date/Time: Sun, 20 Sep 2026 02:50:50 +0000
Auto Plot TPO References
View Count: 911
| [2020-10-29 03:25:35] |
| User139520 - Posts: 28 |
Dear support team, I've been using SC for a few months. I'm loving it so far. Regarding TPO chart, I would like to know if there is a study to automatically plot previous day OHLC, midpoint, value area high and low lines, POC, VPOC, etc. and extend them to the right regardless of them being intersected? I have tried Horizontal Line at Time and daily OHLC studies, but they don't extend and are limited to the OHLC only. Thank you, |
Private File |
| [2020-10-29 15:16:08] |
| John - SC Support - Posts: 47939 |
You would have to setup those lines on a separate chart and then use the Study/Price Overlay in order to see them on the TPO. You will need to set the Input on the Study/Price Overlay for Match Source Bars to Destination Bars to No. When you do this the lines will display on the entire TPO chart. You can change the draw style for the subgraphs to Line at Last Bar to Edge and see if you like that better. Refer to the following along with the link to the Study/Price Overlay: Time Price Opportunity (TPO) Profile Charts: Using Other Studies on a TPO Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
