Date/Time: Wed, 12 Feb 2025 13:37:19 +0000
Study subgraphs reference color and elipse tool
View Count: 499
[2020-10-29 02:25:25] |
User459170 - Posts: 262 |
I am using study subgraphs reference to color an area of my chart. Over this area, in I draw an elipse or a rectangle, they do not show, they seem to be underneath it. However the arrows and lines have no such issues. How do I fix this? Thanks.
[2020-10-29 02:54:23] |
Refer to the documentation here related to this: Chart Studies: Study Display Order Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-10-29 14:56:45] |
John - SC Support - Posts: 37891 |
Also refer to the following setting for Ellipse and Rectangle drawings: Chart Settings: Draw Highlight Drawings Underneath Main Graph and Studies (Chart >> Chart Settings >> Chart Drawings menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-10-29 23:31:21] |
Thanks John, your link solved the problem.
