Date/Time: Wed, 12 Feb 2025 13:37:13 +0000
[User Discussion] - Keyboard Shortcut Minimize Chartbook
View Count: 1300
[2020-10-28 22:42:47]
mmagallanes - Posts: 12
Is there a way to minimize a chartbook, not just a chart, using a keyboard shortcut? Can't seem to find it. Thanks.
[2020-10-29 02:37:50]
No we do not know what is meant by minimizing a Chartbook. You can change to a different Chartbook which is already open through the CB menu.
[2020-10-29 03:21:02]
Calling it a chartbook probably isn’t correct. I’m referring to the main window where I can scroll through the various chartbooks and look at the attached charts. I have multiple detached charts on various screens and minimize the main window as I don’t use the attached charts when I trade. Having a keyboard shortcut would be one less step. Thanks.
[2020-10-29 17:30:24]
Ackin - Posts: 1865
This is a matter not of Sierrachart but of your operating system. If you have Windows - try:
To minimize the current application you're using, press the Windows logo key + the down arrow on your keyboard at the same time. If the current state of the application window you want to minimize is maximized, this keyboard shortcut will have a middle step in which the application window takes its standard size to the desktop (neither minimized nor maximized, normal window only).
Date Time Of Last Edit: 2020-10-29 17:32:30
