Date/Time: Wed, 12 Feb 2025 14:00:57 +0000
[User Discussion] - Which info is correct?
View Count: 429
[2020-10-28 21:57:32] |
Crtfyd - Posts: 281 |
-100 Volume bars -Red Vertical line is "Vertical time line" study that is set for 16:00 -Blue Vertical line is the true 16:00 according to Cross-hairs -Cross-hairs are at 16:59:59.999 -The Horizontal Blue line is a study "Hi-Low for Time Period-Ext" set for 16:00 for Start. So the Study is incorrect. I'm wondering what the problem is. If my data comes in stamped at a certain time, shouldn't the chart recognize the time and label it accordingly? I doubt this is the speed of my laptop for two reasons. Because its pretty fast but moreover this was downloaded form historical days after, so not a live gathering. Is there a "default" I have to change for the studies to recognize the time to sync? Is there a "default" I have to change for the charts to recognize and match milliseconds? Can you think of a workaround if the charts cant recognize/match the provided data timestamps? Thank You. |
Private File |
