Date/Time: Wed, 12 Feb 2025 13:56:38 +0000
How to have crosshair on multiple charts?
View Count: 2619
[2020-10-28 16:44:58] |
User282200 - Posts: 2 |
I was looking how to have the crosshair on multiple charts at the same time, for example: on same stock crosshair to come on 1-5-10minutes etc thank you |
[2020-10-28 16:57:24] |
Ackin - Posts: 1865 |
Try: Global Cursor Chart Drawing Tools: Global Cursor (Tools >> Global Cursor On) |
[2020-10-29 07:25:50] |
Yes the documentation given above is correct.
