Date/Time: Wed, 12 Feb 2025 13:36:26 +0000
footprint
View Count: 635
[2020-10-28 15:18:33] |
User177063 - Posts: 2 |
hello i just downloaded sierra chart and wanted to find out how to add the footprint chart onto it if you can help please
[2020-10-28 15:36:16] |
Graham - Posts: 44 |
The learning curve for SierraChart is a steep one, but all the information is available on the site. Take the time to look through the documentation: https://www.sierrachart.com/index.php?page=doc/Contents.php Footprint charts are called Number Bars: Numbers Bars |
[2020-10-28 20:04:28] |
Refer to the instructions here: Numbers Bars Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-10-28 20:05:15
