Date/Time: Wed, 12 Feb 2025 13:38:14 +0000
Vedios How to use. & what is difference between standard
View Count: 576
[2020-10-28 15:18:23]
User786786 - Posts: 2
or higher version of chart.
last thinkg foot print chart i can move them horizontal but not vertical or 2 my position i prefer. so is difficult.
please inform. though i tried all option you have on right click.
let me know
thanks
[2020-10-29 13:53:58]
John - SC Support - Posts: 37891
We are not sure exactly what you are asking about.
Although it sounds like you are having a problem moving the Numbers Bar chart vertically. You move the Numbers Bars chart in the same way as any other chart. The easiest way is to use the Price Scale and adjust it up or down. Refer to the information here:
Chart Scale and Scale Adjusting: Interactive Scale Move - Move Scale Up and Down
Also refer to the following regarding Scaling a Numbers Bars chart:
Numbers Bars: Scaling a Numbers Bars Chart
