Date/Time: Wed, 12 Feb 2025 13:55:31 +0000
V 2188 / quoteboard : symbol apperas as 0
View Count: 590
[2020-10-28 15:15:47]
User877753 - Posts: 152
V 2188
Quoteboard Symbol appears as 0 for everry line : see attached.
Should be :
CL Dec 20
DAX Dac 20
ES Dec 20
NQ Dec 20
Thanks for your help
Regards
Private File
[2020-10-28 19:45:51]
It looks like you renamed the column titles. Please attach this Chartbook by following these instructions here:
https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile
[2020-10-28 20:48:01]
I noticed that the column values were out of sync with the headers.
I did not change the headers at all : the issue appeared with identical settings when I upgraded to version 2188 today.
V 2187 worked fine : I'm definitely sure of that because I take a lot of screenshots throughout the day.
I restarted Sierra Chart, now the headers are OK. Nevertheless the "Symbol" field is now in last position...
I'm confused.
CHT file attached.
Thanks for your help !
Private File
[2020-10-29 20:20:44]
We really do not know how this condition has developed but if you update to the latest revision of 2189, you need to update again, the Symbol field will be put back to the beginning.
Date Time Of Last Edit: 2020-10-29 20:26:00
