Date/Time: Wed, 12 Feb 2025 13:54:28 +0000
Font on Chart Studies
View Count: 807
[2020-10-28 14:49:59] |
Dt111111 - Posts: 5 |
Hello, is there a way to change the font size only of the values and name labels that you can place for study lines on a chart? Example in attached showing the names that I would like to reduce their font size. Thanks.
[2020-10-28 15:00:35] |
John - SC Support - Posts: 37891 |
The Value and Name labels use the Chart Text Font. It is not supported to be able to change the font just for those items.
