Date/Time: Wed, 12 Feb 2025 13:56:32 +0000
Removing old symbols in the trade activity log
View Count: 720
[2020-10-28 13:59:11] |
ycomp - Posts: 321 |
Trade Activity log over time will collect a lot of old symbols of course. I was wondering if I can remove these symbols from the drop down list by simply deleting older trade activity log files, such as from months before? or is there another way I could do it?
[2020-10-29 03:40:12] |
Yes that is one way to do this. The other method is documented here: Trade Activity Log: Clearing Trade Activity Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-10-29 18:28:20] |
I tried using the method in the link above to remove data for a symbol on all accounts, however it does not remove the symbol from the dropdown box. How can I remove symbols?
[2020-10-29 20:34:41] |
If you restart Sierra Chart and you still see the symbol listed it means there are still Trade Activity records that use that symbol.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-10-29 20:34:46
[2020-10-30 20:09:17] |
didn't work for me.. I tried the edit|clear method and restarting but the symbol still is in the combobox... there are no records when I hit apply but the old symbol is still listed in the combobox. So then I tried another method... I went and delete all files older than october in the TradeActivityLog folder (while sierra was closed of course). Then I restarted and The dropdown box still contains all these old symbols.. that have old month codes in them like H or M Date Time Of Last Edit: 2020-10-30 20:09:54
