Date/Time: Wed, 12 Feb 2025 14:16:25 +0000
Missing dialog box - V 2187
View Count: 621
[2020-10-28 10:49:52] |
User877753 - Posts: 152 |
Hello, I upgraded this monring to V 2187. 2 dialog boxes do not appear anymmore : - Global settings / General Trade Settings : nothing pops up - in DOM windows : when modifiyng an order, nothing appears ; the Quantity/Price Modification box does not appear. V 2182 worked fine. Thanks for your help. JM |
[2020-10-28 11:15:06] |
We are checking on this now.
[2020-10-28 12:33:37] |
This is now resolved in version 2188. Update with Help >> Download Current Version.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-10-28 12:33:43
[2020-10-28 15:03:24] |
Problem solved with 2188. Thanks.
[2020-10-29 07:25:09] |
If you have any further issues use version 2189.
