Date/Time: Wed, 12 Feb 2025 13:58:09 +0000
Slope of MA in degrees?
View Count: 562
[2020-10-28 08:19:09] |
Tonkadad - Posts: 235 |
Is is possible to get the slope of an MA in degrees and then using the Text Display For Study to show it on a chart?
[2020-10-28 12:35:04] |
Yes. Use the following two studies: Study Angle Text Display For Study Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-10-29 07:38:25] |
Once again thank you, works perfectly!
