Date/Time: Wed, 09 Sep 2026 04:40:47 +0000
Es data issue
View Count: 750
[2020-10-27 20:07:34]
User525965 - Posts: 180
Hi, I have a data error on all my ES charts. Is there a way to get this corrrected?
I have TT data
image2020-10-27_16-07-09.png / V - Attached On 2020-10-27 20:07:26 UTC - Size: 92.47 KB - 317 views
[2020-10-27 20:50:17]
John - SC Support - Posts: 47806
Follow the instructions at this link to delete and download the data starting from just before where the problem is showing.
Data Errors or Spikes in Charts, Flat or Flat Line Graph, Compressed Graph, Errors with Date/Time Values: 2.1.2 Deleting and Re-downloading Data. (Easier and Recommended Method)
Date Time Of Last Edit: 2020-10-27 22:14:00
[2020-10-28 12:37:03]
You are not using TT data. You are using the Denali Exchange data feed. There should never be a data error. This is a nonexistent issue. So we are not sure what happened in your case.
We want you to update to the current version:
