Date/Time: Wed, 12 Feb 2025 14:06:13 +0000
Display Option for TPO Chart Point of Control
View Count: 480
[2020-10-27 18:20:22] |
User450463 - Posts: 128 |
Is it possible to display two points of control simultaneously, one based on volume, the other based on time? Thanks |
[2020-10-27 20:23:47] |
John - SC Support - Posts: 37891 |
No, this is not supported. The best you could do would be to setup a Volume by Price study that is based on the TPOs and then display the Volume Point of Control from the VbP and use the TPO POC from the TPO. Refer to the following for information on adding the VbP to the TPO: Time Price Opportunity (TPO) Profile Charts: Displaying Volume Profiles For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-10-28 08:15:01] |
Would it be possible to add this? A lot of profile traders like to look at both. In the meantime I will examine the alternative you suggest.
