Date/Time: Wed, 12 Feb 2025 14:04:17 +0000
Volume study - grid
View Count: 599
[2020-10-27 15:20:40] |
manfretto - Posts: 117 |
Hello, Is it possible to have grid on volume study? |
[2020-10-27 15:35:49] |
John - SC Support - Posts: 37891 |
We need more information to know what you mean by a grid. We think you may be referring to the horizontal grid, in which case refer to the following and the setting following it: Chart Scale and Scale Adjusting: Horizontal Grid Line Increment (Scale Settings) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-10-28 08:32:14] |
Hi, I used above link plus Chart->Horizontal Grid -> Region 2 It works now. Thank you. |
