Date/Time: Wed, 12 Feb 2025 13:38:15 +0000
Graphics Settings - Global (bars colouring)
View Count: 480
[2020-10-27 15:04:38] |
manfretto - Posts: 117 |
Hi, I would like to have green (Open, High-Low Up, Close) for up-bars and red for (Open, High-Low Down, Close). I see that 'Graphics Setting- Global' does not distinguish Open and Close for up and down bars. |
[2020-10-27 15:27:34] |
User907968 - Posts: 826 |
Graphics Settings: Up/Down Coloring for OHLC Bars Based on Previous and Current Close (Global Settings >> Graphics Settings >> Other)
[2020-10-28 04:48:59] |
Let us know if you need more help.
[2020-10-28 08:13:54] |
What I really needed was : Color Entire OHLC Bar the High/Low Color (Global Settings >> Graphics Settings >> Other). It works now. Thank you. |
