Date/Time: Wed, 12 Feb 2025 14:19:35 +0000
Three or more stopp buy - stopp sell orders
View Count: 521
[2020-10-27 14:34:07]
goodness - Posts: 8
I would like to generate 3 or more stopp sell/buy orders with one click.
How can I realize that?
[2020-10-27 14:38:04]
John - SC Support - Posts: 37891
If you are asking to have 3 separate orders with a single click, then that would need to be done using a custom study. Refer to the information starting here:
Advanced Custom Study Interface and Language (ACSIL)
If you are asking about the quantity, then refer to the following for how to set the quantity for an order:
Chart Trading and the Chart DOM: Changing Order Quantity
[2020-10-28 04:50:06]
Also have a look at Attached Orders:
Attached Orders
[2020-10-28 11:35:59]
goodness - Posts: 8
Thx, where can I find the buy stopp orders as ACSIL? My idea is, to copy that sequence to modify it.
Is that possible?
[2020-10-28 13:38:27]
You will find the trading examples in the file tradingsystem.cpp which is located in the ACS_Source directory under the main Sierra Chart installation folder.
[2020-10-28 14:06:17]
goodness - Posts: 8
Thx
[2020-10-30 09:42:14]
goodness - Posts: 8
hi john,
perhaps, would you mind to give me a small hint. i have generated my own
custom file as indicator (see attachment), but how can i use that "indicator"
similar buy/sell order button? I dont know, how to activate the order.
Private File
Private File
[2020-10-30 13:58:39]
That is what you need to figure out in your code. What are the circumstances under which you want an order to be placed, then you place the order through your program.
Refer to the information on this page for more:
Automated Trading From an Advanced Custom Study
