Date/Time: Sat, 04 Jul 2026 04:33:07 +0000
AMP Futures and I.B for Trading Stocks
View Count: 964
[2020-10-27 13:05:14]
CFC - Posts: 9
I am in the process of opening a trading account with AMP Futures to trade the ES & NQ. I also like trading stocks and currently use Interactive Brokers. If i use the sierra charts that comes with the AMP Futures account can I configure it so I can trade the futures contracts through AMP and the stocks through I.B with stock data from sierra charts(I heard that sierra charts data is better than I.B stock data) or does the Sierra charts you get from AMP only allow you to trade the futures via AMP.
[2020-10-27 14:34:23]
John - SC Support - Posts: 47017
The Sierra Chart you get from AMP only allows you to trade through AMP. You would need to have a direct account in order to do what you are proposing. Refer to the information here:
Direct Sierra Chart Account
[2020-10-27 18:10:36]
CFC - Posts: 9
Thanks for the link, so just to confirm. If I pay for Sierra Charts can I configure Sierra Charts so I have it linked to my 2 brokers at the same time(AMP & I.B) and have 2 data feeds connected at the same time (CQG from AMP Futures and Stockmarket Data from Sierra charts)
[2020-10-27 18:17:03]
You will want to have 2 different installations of Sierra Chart, one for the AMP connection and one for the IB connection, but otherwise yes, you can have them both connected at the same time and receiving their respective data.
There is no extra charges for additional installations of Sierra Chart on the same computer. You can also have 2 installations running at the same time on different computers. But if you wanted to have third computer at the same time, then that would be an extra cost. Refer to the information here on this topic:
Sierra Chart Purchase and License Information: Licensing / Number of Systems
[2020-10-29 20:19:22]
Also refer to:
Using Multiple Data and Trading Services at the Same Time
