Date/Time: Sun, 04 Oct 2026 15:55:58 +0000
Spreadsheet and study values
View Count: 995
| [2020-10-27 06:49:53] |
| Tonkadad - Posts: 235 |
If I wanted to have the stochastic value for the same symbol but different TF's 1,3 and 5 minute, can I do that in a spreadsheet? Is there a way to export those numbers onto a chart? Or control bar? Thank you! |
| [2020-10-27 07:15:14] |
| Ackin - Posts: 1865 |
NoAt the user level: Duplicate the chart, set a higher timeframe and transfer values via study price overlay to the original chart |
| [2020-10-27 09:51:11] |
Refer to this study here to do this: Study/Price Overlay Study Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2020-10-27 15:29:15] |
Thanks for the responses, looking for a numerical display of info as opposed to graphical. Ideally it would be 3 text boxes displaying the number value.
| [2020-10-27 15:38:40] |
| John - SC Support - Posts: 48095 |
Refer to the following study: Text Display For Study from Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2020-10-27 16:29:55] |
Awesome John exactly what I wanted. Thank you |
| [2020-10-27 17:10:01] |
Anyway to get a label attached to the text display
| [2020-10-27 17:43:16] |
You can add Prefix and Suffix Text through the Inputs for the study. Refer to the information on this page for the Inputs: Text Display For Study For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2020-10-27 20:29:38] |
Sorry for wasting your time I should have seen that. Great support! |
