Date/Time: Wed, 12 Feb 2025 13:40:00 +0000
AMP GLOBAL
View Count: 1196
[2020-10-27 04:00:37]
User169391 - Posts: 62
HI,
Amp global provide forex and cfd trading through there MT4 AND MT5 packages. I have an account with AMP. My question is can I trade forex using sierra charts and sierra data feeds to trade on my AMP account. Would this also apply to futures, indices, emini's etc which AMP Global supports. Looking to have an all in one account.Currently with FXCM.
thanks
[2020-10-27 09:38:40]
No, only futures trading through AMP is currently supported.
[2020-10-27 21:46:55]
Hi
If I was to use InteractiveBrokers and your data feeds would I still need to connect through the API to TWS. Does this fix the major issues you have had with this broker?
[2020-10-28 04:38:36]
You would only need to connect to Interactive Brokers TWS if you want to do trading from Sierra Chart of your Interactive Brokers account.
Otherwise, you can use the data feeds independently. Refer to:
Real-Time Exchange Data Feeds Available From Sierra Chart
Date Time Of Last Edit: 2020-10-28 04:39:20
