Date/Time: Wed, 12 Feb 2025 10:38:08 +0000
data
View Count: 420
[2020-10-26 15:12:12]
g4500 - Posts: 27
Hi
I just registered on trial but no delayed data.
It look like disconnected.
Can you help me?
[2020-10-26 16:18:10]
John - SC Support - Posts: 37891
First, you need to complete the Uniform Subscriber Agreement for Delayed Data. You can access this from this page:
https://www.sierrachart.com/UserControlPanel.php?page=ExchangeAgreements
Second, are you having a problem with the Status window showing that you are Disconnected? If so, then select File >> Connect to Data Feed, and see if you connect. If you still have a problem then get us your Message Log by following these instructions:
Reconnect to the data feed:
https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog
