Date/Time: Wed, 12 Feb 2025 16:08:32 +0000
Charts are very slow to apply changes!
View Count: 542
[2020-10-26 14:35:21]
User108250 - Posts: 16
Subject updated from 'Trading Account Assignment Request Form' to 'Charts are very slow to apply changes!'
Charts are very slow and it looks like it is disconnecting frequently, and it takes long time to refresh after any changes in the chart settings or any changes Studies settings or any changes in scales while I am trading E-Mini ES!
And the problem will get bigger if I am trying Crude Oil Future (CL), Natural Gas (NG) or Gold (GC!
Please advise ASAP!
[2020-10-26 15:53:56]
John - SC Support - Posts: 37892
Refer to the information here:
High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often
[2020-11-03 17:37:19]
Thanks, everything seems to work better now!
Also, I have a question on how can I get the code of the "Polynomial Regression Channel" custom study? because I have some ideas for it, and I may need to tweak it a little bit!
[2020-11-03 17:40:16]
The Polynomial Regression Channel is in the Studies5.cpp file in the ACS_Source directory under your main Sierra Chart installation directory.
Refer to the following for how to compile a custom study:
How to Build an Advanced Custom Study from Source Code
Date Time Of Last Edit: 2020-11-03 17:40:57
[2020-11-04 13:11:10]
Thank you so much!
