Date/Time: Wed, 12 Feb 2025 11:06:19 +0000
Same Study needs different Values for each Symbol
View Count: 682
[2020-10-26 14:04:43]
User924090 - Posts: 3
Hi Sierra Chart team,
I have a question to the Volume at Price Threshold Altert V2.
My Chartbook has 4 intraday charts which are linked to a quoteboard so that I can easily swicht from symbol to symbol and all 4 charts show the same for example CL.
The problem I have with the Threshold Study is that the values I set within the study stays the same if I change to another symbol.
For example I set the Study in Crude Oil to Total Volume and 150. So every Volume in a bar above 150 is highlighted. Very nice btw. :)
If i switch now to Gold for example the volume of 150 to highlight is too much. I need this to set lower, because there are not so many contracts traded. The study doesn't save the value for the specific symbol. Do you know how this can be solved?
Thanks in advance.
Sincerly
Sven
Date Time Of Last Edit: 2020-10-26 18:15:45
[2020-10-26 20:33:19]
You need separate charts with each one configured as you require. Also refer to:
Study Collections
[2020-10-26 21:18:18]
That's a pity, because the Quoteboard and all the charts linked together for a fast swicht is so neat to use. That's what I love so much about Sierra Chart.
