Date/Time: Mon, 25 Nov 2024 12:46:30 +0000
no connection to the data-feed
View Count: 1117
[2014-02-12 13:07:19]
User14368 - Posts: 1
Software version: 1090 | 2014-02-12 12:50:22
Usage end date: 2014-05-14 | 2014-02-12 12:50:22
Enabled for: Sierra Chart Historical Data Service. | 2014-02-12 12:50:22
Allow Support for Sierra Chart Data Feeds is enabled. | 2014-02-12 12:50:22
Active service: IQFeed | 2014-02-12 12:50:22
Time Zone: +00:00:00 (UTC+00) | 2014-02-12 12:50:22
2014-02-12 13:50:22 Local computer clock time | 2014-02-12 12:50:22
2014-02-12 12:50:22 GMT time | 2014-02-12 12:50:22
2014-02-12 12:50:22 Time zone adjusted time | 2014-02-12 12:50:22
Time difference to server time: 0 seconds. | 2014-02-12 12:50:22
Program path: C:\SierraChart\ | 2014-02-12 12:50:22
Data Files path: C:\SierraChart\Data\ | 2014-02-12 12:50:22
OS Version Number: 6.1 | 2014-02-12 12:50:22
Checking for new symbol settings for dtn | 2014-02-12 12:50:22
Symbol settings are up-to-date for dtn | 2014-02-12 12:50:22
IQ Feed: Connecting. | 2014-02-12 12:50:27
Starting DTN IQ Feed interface software. | 2014-02-12 12:50:27
Error starting IQ Feed interface software. Error code: 2 | 2014-02-12 12:50:27
IQ Feed: Failed to look up the port number for the Admin connection. | 2014-02-12 12:50:27
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-02-12 12:50:27
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-02-12 12:50:27
IQ Feed: Fully disconnected. | 2014-02-12 12:50:27
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-02-12 12:50:27
IQ Feed: Connecting. | 2014-02-12 12:50:32
Starting DTN IQ Feed interface software. | 2014-02-12 12:50:32
Error starting IQ Feed interface software. Error code: 2 | 2014-02-12 12:50:32
IQ Feed: Failed to look up the port number for the Admin connection. | 2014-02-12 12:50:32
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-02-12 12:50:32
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-02-12 12:50:32
IQ Feed: Fully disconnected. | 2014-02-12 12:50:32
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-02-12 12:50:32
IQ Feed: Connecting. | 2014-02-12 12:50:37
Starting DTN IQ Feed interface software. | 2014-02-12 12:50:37
Error starting IQ Feed interface software. Error code: 2 | 2014-02-12 12:50:37
IQ Feed: Failed to look up the port number for the Admin connection. | 2014-02-12 12:50:37
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-02-12 12:50:37
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-02-12 12:50:37
IQ Feed: Fully disconnected. | 2014-02-12 12:50:37
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-02-12 12:50:37
IQ Feed: Connecting. | 2014-02-12 12:50:42
Starting DTN IQ Feed interface software. | 2014-02-12 12:50:42
Error starting IQ Feed interface software. Error code: 2 | 2014-02-12 12:50:42
IQ Feed: Failed to look up the port number for the Admin connection. | 2014-02-12 12:50:42
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-02-12 12:50:42
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-02-12 12:50:42
IQ Feed: Fully disconnected. | 2014-02-12 12:50:42
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-02-12 12:50:42
IQ Feed: Connecting. | 2014-02-12 12:50:47
Starting DTN IQ Feed interface software. | 2014-02-12 12:50:47
Error starting IQ Feed interface software. Error code: 2 | 2014-02-12 12:50:47
IQ Feed: Failed to look up the port number for the Admin connection. | 2014-02-12 12:50:47
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-02-12 12:50:47
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-02-12 12:50:47
IQ Feed: Fully disconnected. | 2014-02-12 12:50:47
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-02-12 12:50:47
IQ Feed: Connecting. | 2014-02-12 12:50:52
Starting DTN IQ Feed interface software. | 2014-02-12 12:50:52
Error starting IQ Feed interface software. Error code: 2 | 2014-02-12 12:50:52
IQ Feed: Failed to look up the port number for the Admin connection. | 2014-02-12 12:50:52
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-02-12 12:50:52
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-02-12 12:50:52
IQ Feed: Fully disconnected. | 2014-02-12 12:50:52
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-02-12 12:50:52
IQ Feed: Connecting. | 2014-02-12 12:50:57
Starting DTN IQ Feed interface software. | 2014-02-12 12:50:57
Error starting IQ Feed interface software. Error code: 2 | 2014-02-12 12:50:57
IQ Feed: Failed to look up the port number for the Admin connection. | 2014-02-12 12:50:57
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-02-12 12:50:57
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-02-12 12:50:57
IQ Feed: Fully disconnected. | 2014-02-12 12:50:57
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-02-12 12:50:57
IQ Feed: Connecting. | 2014-02-12 12:51:02
Starting DTN IQ Feed interface software. | 2014-02-12 12:51:02
Error starting IQ Feed interface software. Error code: 2 | 2014-02-12 12:51:02
IQ Feed: Failed to look up the port number for the Admin connection. | 2014-02-12 12:51:02
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-02-12 12:51:02
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-02-12 12:51:02
IQ Feed: Fully disconnected. | 2014-02-12 12:51:03
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-02-12 12:51:03
IQ Feed: Connecting. | 2014-02-12 12:51:08
Starting DTN IQ Feed interface software. | 2014-02-12 12:51:08
Error starting IQ Feed interface software. Error code: 2 | 2014-02-12 12:51:08
IQ Feed: Failed to look up the port number for the Admin connection. | 2014-02-12 12:51:08
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-02-12 12:51:08
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-02-12 12:51:08
IQ Feed: Fully disconnected. | 2014-02-12 12:51:08
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-02-12 12:51:08
IQ Feed: Connecting. | 2014-02-12 12:51:13
Starting DTN IQ Feed interface software. | 2014-02-12 12:51:13
Error starting IQ Feed interface software. Error code: 2 | 2014-02-12 12:51:13
IQ Feed: Failed to look up the port number for the Admin connection. | 2014-02-12 12:51:13
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-02-12 12:51:13
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-02-12 12:51:13
IQ Feed: Fully disconnected. | 2014-02-12 12:51:13
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-02-12 12:51:13
[2014-02-12 18:44:45]
The problem is you want to use IQ Feed, but you do not have the IQ Feed software installed on your system. Follow step number 2 here:
http://www.sierrachart.com/index.php?l=doc/DTNIQFeed.html#Setup
