Date/Time: Wed, 12 Feb 2025 11:09:58 +0000
SierraChart versions 2098
View Count: 653
[2020-10-26 12:23:25] |
User36553 - Posts: 25 |
Hi All, Can I've the SierraChart 2098 version because I need this version to reintall to my computer to connect Rithmic server. Regards, Michael |
[2020-10-26 15:43:30] |
John - SC Support - Posts: 37891 |
Refer to the information here for how to install a specific version: Software Download: Full Control Rollback Procedure Although we have not yet removed support for Rithmic from within the software, we are only not giving technical support for it. So you could still install the current version. In any case, make sure you get the updated Bridge Files installed. Refer to the information here: Rithmic Bridge Files For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-10-26 19:11:21] |
You do not need an older version of Sierra Chart. Only run the current version. You will need the Rithmic bridge files here: Rithmic Bridge Files Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
