Date/Time: Wed, 12 Feb 2025 11:00:17 +0000
SIERRA CHART MOBILE?
View Count: 1902
[2020-10-26 00:40:02] |
User55361 - Posts: 7 |
I just recently started back up service since 2016. Is there a way to have Sierra Chart Services on Mobile device, phone or tablet? |
[2020-10-26 03:55:04] |
There is web-based trading functionality which can be used on a mobile device if you use the Sierra Chart Order Routing Service: https://www.sierrachart.com/index.php?page=doc/SierraChartOrderRoutingServiceWithData.php# Specifically refer to: https://www.sierrachart.com/index.php?page=doc/SierraChartOrderRoutingServiceWithData.php#WebBasedTradingPanel Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-10-26 03:56:28
