Date/Time: Thu, 10 Sep 2026 09:40:22 +0000
TPO - Color Code TPO Rows Based on Percentage of POC Volume
View Count: 1761
| [2020-10-24 17:27:13] |
| User992529 - Posts: 32 |
I would like to request for a similar feature already existing in Volume by Price "Color Code Volume Bars Based on Percentage of POC (Volume)" to be add in the TPO Study as well. Proposal - add to settings of TPO Study: Color Code TPO Rows Based on Percentage of POC Volume Number of POC Ranges to Color 0%-10% POC Color 10%-20% POC Color ... 90%-100% POC Color Expected Result: The coloring would happen by horizontal TPO rows (equivalent to the Volume bars in the other Study). |
| [2020-10-26 04:25:42] |
We will look into this.
| [2020-11-16 06:41:22] |
I have included an example attached. The Volume coloring is 30-40-30 light blue, blue, dark blue (in terms of settings 70-100% light blue, 30-70% blue, 0-30% dark blue). The TPO coloring is also 30-40-30 magenta, red, white (in terms of settings 70-100% magenta, 30-70% red, 0-30% white). The behavior is 1:1 with Jim Dalton's Market Profile courses examples. |
Private File |
| [2021-01-08 00:19:27] |
| Sierra_Chart Engineering - Posts: 24821 |
This feature will be included in the next release.
| [2021-01-19 04:52:53] |
I tried both Current (2219) from 12 Jan and PreRelease (2220) however I cannot find the option neither in TPO nor in VbP studies. Can you please advise location / naming of the new option? My assumption is next release is the next release after your message (8 Jan) which is 2219 (12 Jan). If it's not yet released, then I extend my friendly apologies for the misunderstanding. |
| [2021-02-02 03:37:08] |
Dear Sierra Chart Engineering, Thank you very much for including the feature (using 2226 right now). It works exactly as intended. I would like to add two things to the specification to polish this furter as I didn't think of them initially some corner cases / interactions with the other options. Proposal 1: Lower the priority of the drawing of the new "TPO Row Based on Percentage of POC" option (drawing it earlier). Currently if: Highlight Open in Profile (ln:9) = Yes Highlight TPO POC (ln: 48) = Yes Color TPO Row Based on Percentage of POC (ln: 125) = Yes then the coloring of the TPO row will overwrite the other two highlights. Expected result: Open and POC would be colored after the TPO Row coloring. This is especially needed together with Proposal 2 (POC by TPO while keeping TPO Row coloring by Volume). Note/Corner Case: The order of TPO Row coloring and VA is non-issue because I expect users will use one or the other and not both at the same time. Proposal 2: Unlink the "Color TPO Row Based on Percentage of POC (ln: 125)" to the option "Point of Control Highlight Based on Volume (ln: 12)". My assumption is users either will use VA highlighting or Volume highlighting but not both while still allowing the VA and POC to be TPO based and not Volume based. If Color TPO Row Based on Percentage of POC (ln: 125) = Yes Expected result: always color by Volume and not based on ln:12. Cosmetically I would add "Volume" in the name also "Color TPO Row Based on Percentage of POC Volume". With Proposal 1 & 2, one would be able to draw the TPO-based POC while still keeping TPO row coloring by Volume. Thank you. |
| [2021-02-03 12:21:31] |
We will look this over.
| [2021-02-19 00:47:47] |
Update to the latest release. We have implemented what is described in post #6.
