Date/Time: Wed, 12 Feb 2025 11:17:40 +0000
Point & Figure bar direction
View Count: 458
[2020-10-23 16:22:58] |
Thurston - Posts: 9 |
I am using the new Point and Figure Bar Period Type and need to know the current bar direction (X or O ; up or down) from within my acsil program. Where is that information kept and how do I access it? Thanks.
[2020-10-26 19:45:55] |
Refer to: sc.BaseData[PF_DIRECTION_ARRAY] Here: ACSIL Interface Members - Variables and Arrays: sc.BaseDataIn[][] / sc.BaseData[][] Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
