Date/Time: Wed, 12 Feb 2025 14:00:57 +0000
[User Discussion] - Shortcut for Tools Lock and Indicator
View Count: 595
[2020-10-23 13:32:58] |
RolandC - Posts: 54 |
Is there a way to create a keyboard shortcut for protecting / locking tools. Example, if I draw a Ray and I want to protect / lock it, I have to open the Ray Properties Box and select Lock, this has to be done a lot. The ability to use a keyboard shortcut to say Lock a Ray would save a lot of time. My second question, is there any way to know if a Ray is locked? For example, if not, do you think putting a small lock symbol somewhere on the tool,Text, Ray or what ever is a good idea? Thanks |
[2020-10-28 08:50:25] |
User90125 - Posts: 715 |
Try highlighting the Ray, right-click the Chart Drawing Menu, and select Lock Drawing. Of course, this presumes you have customized your Chart Drawing Menu with the Lock Drawing selection. |
[2020-10-28 08:53:26] |
Amazing, thanks
