Date/Time: Thu, 28 Nov 2024 22:39:18 +0000
[Locked] - Stocks & options trading with Sierra charts
View Count: 4984
[2020-10-23 05:07:37] |
User798135 - Posts: 11 |
Hi, I have a Sierra charts subscription thru AMP futures to trade Futures. If i wish to trade stocks & options using sierra chart system, how do i subscribe to real-time data for stocks & options. Also, how do i link Sierra charts with my existing Interactive brokers account? Thanks. Sonny |
[2020-10-23 05:42:51] |
Sierra Chart does not provide stock options data. For stock data you need to use the Sierra Chart Exchange Data Feed: Sierra Chart Exchange Data Feed Regarding using Interactive Brokers, you need a direct account: Direct Sierra Chart Account When you are using Sierra Chart that has been provided through an affiliate, you do not have a direct paid account with us, and you wish to access functionality that is not provided in your limited version, you must have an account with Sierra Chart directly and have a standard installation of Sierra Chart. To accomplish this, follow the instructions below: Direct Sierra Chart Account Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-10-23 12:56:15] |
If I obtain a direct Sierra account, would i be able to access my real-time data from Interactive brokers with regards to stocks & options? Thanks. |
[2020-10-23 18:44:25] |
Yes in regards to stocks. With Interactive Brokers options you are going to have a lot of difficulties with that which we will not help with.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-03-18 14:03:52
