Date/Time: Wed, 12 Feb 2025 10:43:39 +0000
[User Discussion] - VbP Displacement
View Count: 483
[2020-10-22 21:48:38] |
User311344 - Posts: 142 |
There's an option for every subgraph in any study to shift it left/right using [Displacement] input. Is there any way to shift the VolumeByPrice study same way? For example 3 bars to the right vs it's original location. Thanks
[2020-10-22 22:22:27] |
There is no support for this type of Displacement with the Volume by Price study.
[2020-10-22 22:26:54] |
Thanks Any plans of enabling this? |
[2020-10-26 14:40:18] |
Any chance you could add displacement option for VBP study?
